1 - 4 of 4 Posts
My car is a '95 convertible. All windows work, all door locks work. The ONLY switch that doesn't function is the window switch on the passenger side. I replaced it with a new one yesterday and it still doesn't work.
Is this one of those deals where the passenger side switches actually get power through the driver side switches? I've seen some cars like that before. It's odd. Or should I be looking somewhere else?
I believe they are wired in series like you said. Check the drivers side switch for corrosion and loose wires.
Sent from my iPhone using Tapatalk
I found a new driver side switch so I'll give that a shot and inspect the wiring this week. Thanks.
  • Like
Reactions: 07gtS197
I replaced the driver side switch and it's all working well now. So apparently the passenger switch DOES get it's feed from the driver side. Odd! But at least it works!
1 - 4 of 4 Posts
