1 - 7 of 7 Posts
you should only need to change the pedal cover, im not sure why you would change the arm and all. you just pull the little rubber cover off, then mount the other on.
no there is like a pin on the gas pedal there is no rubber piece
huh, my 99 GT just had a little rubber boot over the metal pedal like the brake, and clutch.
tap the pin out with a hammer
1 - 7 of 7 Posts
