1 - 20 of 20 Posts
Is a 351w piston the same as a 302? Is the centerline of the wrist pin the same distance from the top ring land. I have a 351 block, and I have fly cut stock 5.0 pistons, I also have no money left(reason for question), can I use the 5.0 pistons in the 351, with the stock length connecting rods and crank?
would you happen to know the diffrence in the distance?
1.600
1.772
these are the most common aftermarket heights, just look at it. The 351 has a deck height of 9.5 vs 8.2 and the rod is 5.956 vs 5.090
Thats good info to know right there. I never knew the actual compression height of 302 pistons. Nice to have a comparison with 351 slugs.
Rod length + (1/2 stroke) + piston comp height = block deck height
for a 302
5.090+ (1/2*3) + x = 8.2; x = 1.61 comp height for zero deck
for a 351
5.955 + (1/2*3.5) + x = 9.5 ; x = 1.795 com height for zero deck
usually you want a little under zero deck to allow for rebuild clean up of the deck.
So yeah you can use them, but you'll have a compression ratio of like 3:1.
A 302 piston is a 393 stroker piston but other than that Woody and Ryan covered the rest.
The up side is you have the pistons and rods for a 393, just need the crank (and balanced , don't forget balanced) :cool:
I think a 393 uses like a 6.1" rod.
THere is a cheap 377 stroker that consists of 302 pistons, chevy rods (I think), and an offset ground 351 with the rod journals cut down to chevy size...
stock 5.956 windsor rod, 1.600 302 piston and a 200 dollar cast crank
I stand corrected. Is this a decent set up...seems like a lot of stroke for that rod.
Is anyone making forged 302B pistons?
The 393 is as old as the hills, the number one downside for me personally is balancing them, they can be an absolute wallet drainer depending on the parts used.
Discussion Starter · #18 ·
excuse me, your raining on my parade:D
Wallet drainer? With a stock rod and stock pistons and $200 crank?
you lost me?
1 - 20 of 20 Posts
