1 - 6 of 6 Posts
Mr Pimpdaddy
Hello Again ,
I have a 94 mustang with a FADED green paint job, ( Hood is bad )
Im looking to through a litthe plasti dip on it ( temp until paint job ), ( anything will look better than what's on it )
Maby Pin Stripes running down the hood , roof and bumper ?
SOmething Like this > Picture
( looking to do rims also ) ( white plasti Dip )
Please any suggestions ?
Custom ideas ?
Canon Gang
You can do stripes, but you have to be QUICK. As the stuff dries, and you go to pull up your taped lines, it will peel the stripe off with it. You have to spray an extremely light tack coat, then an extremely wet coat, and immediately pull the tape.
My whole car is dipped matte white.
Agreed, but you are going to want to do more than 1 heavy coat. I would recommend a good 3 or 4 coats for good coverage, durability, and potential removability.
The cleanest way to achieve that many coats with stripes would be to tape you lines, spray, and remove tape when wet... Then repeat this process for every coat.
Its more tedious, but will look the best
1 - 6 of 6 Posts
