Well, I've heard the term cradle used for 2 different things, one is like an engine stand only a cradle usually sits a bit lower to the ground and is not rotate-able, and the second term is the subframe that holds the entire motor into a car, most newer GM FWD vehicles have a separate subframe that holds the motor in (and usually the 2 bolts on the rear rust out and drop the motor from the car)
