1 - 11 of 11 Posts
So pretty soon I am going to be putting a GT takeoff front and rear sway bar on my V6. I was wondering if I should get the poly bushings for the sway bars? I also heard the shifter poly bushings helped too. Looking for any opinions on if these help anything
I think I heard that poly bushings are too stiff for a street set-up. But I am not too sure, so wait for others to chime in.
Are you still going to just lower the back with Roush springs or do you undertand why its a bad idea now?
I have no experience with the mustang yet. I just purchased my a few months ago.
But am also planning on changing out the rubbers for polys in lots of locations.
I have done this to my previous cars (2006 eclipse, and 2003 eclipse) and loved the outcome. Better control, less slop, overall just a tighter handling car. But I also did more than just swaybar bushings; Control arms, shifter, motor mounts.
I say polys are good.
i have polyurethane bushings in my adj. upper control arm, adj. panhard rod and billet aluminum lower control arms. They are much stronger than stock and they transfer very little noise to the cabin. I don't notice them being any stiffer, but I also have tokico d specs that are on setting a little stiffer than stock
EDIT: you just have to remember to grease the bushings every oil change and make sure you AVOID all greases that have petroleum. They will destroy the bushings
Well the only ones I would be putting on are the bushings on the sway bars since I will be switching to the GT sway bars. I also heard that putting a poly bushing on your shifter gets rid of some of tightness between 2 and 3rd gear on manuals
for the shifter I'm not sure, I have an auto :D
but what about the sway bar bushings then
i'm not too sure what the question is...if you think it will be stiffer, then yes it will be a little stiffer nothing too serious though. I have a stock gt sway bar so I'm not 100% sure. If you are going with urethane bushings I would put a little grease on them so they don't squeak and make unwanted noise
I have poly bushings on the lower control arms and a poly bushing and spherical bearing on the upper and it works fine for me. I plan on switching to spherical rod ends on the upper and lower control arms in the near future. I will get the Steeda Race upper and Race lowers, since I am not worried about the noise that they make. But I must say that the rod ends on the pan hard bar make a lot of noise when driving over bumps and turning.
1 - 11 of 11 Posts
