1 - 6 of 6 Posts
So many mods, so little $
So two issues I've got going on right now are that my driver side window squeaks when it is rolled up/down. It doesn't do this when it's wet though. Also, there have been a couple times when I have filled up at a gas station and it won't crank on the first try.. Anyone got any solutions for either of these? Gracias in advance :)
White lithium grease it its the window motor gears, silicon lube if it's the plastic. Works like a charm. Can you discribe the cranking problem a little more? What's it doing?
Super Moderator
I clean and lube my window wipers as well because they can cause squeeling from debris and drying out window wiper seals.
This has only happened a couple times but I'll fill up and turn the key and it won't start. It usually will start the next around though. It's more annoying than anything.
1 - 6 of 6 Posts
