Hey guys, i was trying to look for next winters Project for my Mustang And i want to do a 347 Stroker and was hoping you could help me out. I want to try to figure out how much it would cost me and what all i should get so that i can know how much i need to save up, and if its even possible with my budget.
First off i have the following mods done ( hoping i can reuse them and save me money )
-TrickFlow Track heat Upper and lower intake
-Roush 200 Heads - 200cc Running Intakes with 64cc Comb.Chambers
-Crane 1.6 RR
-190 LPH In take Fuel Pump with Rails and adjustible fuel Regulators
-MSD Full Ignition
-75MM TB
-90mm MAF Meter ( I think the guy before me got it off a Lighting? )
-F cam ( POS! ) -I was thinking of going with a Anderson Cam for build?
-28oz Balancer
-24 lb injectors (assuming ill need new ones, 30lbs or so?)
-Underdrive pullies
Ok well thats the important stuff, that i can think of just engine right now. Was hoping to be able to use All this for my build? Minus Cam and 24 lb Injectors, is that plausible?
Also what kit should i use if im on a tight budget? Ive looked at some, also noticed FordStrokers doesnt do Kits anymore?:dunno So i dont know what best for my build and i know you guys know more than i do so id appreciate the help. Im not looking for kill it and make 600HP and spend no money. I just want something i can use on the street and take it to the track in the summer. But want to be safe and not risk cracking the block but want it also strong enough to hold up under WOT.
Also other than a stroker kit itself what other expenses should i calc. into this? Will i need diff push rods, Lifters, I assume i will need a diff. Oil Pan but one with a pump or without? This is the stuff i dont know guys. Sorry to ask dumb questions but i seriously, greatly appreciate your help!
-Crane 1.6 RR
-MSD Full Ignition
-75MM TB
-28oz Balancer
-Underdrive pullies
