I was assuming that would have to come down. But what worries me is what is just in front of it, the pan is half over a control arm frame and the other half (belly) over the k member. Will it be able to angle itself out once the k member is out of the way?To my knowledge you have to drop the k member to get it out with the engine in the car.
Aweso....wait its just an oil leak lol. But i do have in mind a split port winstar sawp.welp, looks like it's time for a motor build!
:facepalm:why rebuild a motor that just broke-in? if it aint broke dont fix it. remeber the mbabbit guy? 600K+ miles original eng. and internals. just clean the leaking area really good with a carb cleaner so there is absouletly no oil or dirt then scratch it a bit with sand paper and cover the whole area with permatex black. i have done this on timing cover leak and it has lasted 2 1/2 years now no leak. if its dont right it can work.
i have a minor leak at the front crank main seal and that will require a seal replacement. make sure you know where its coming from so you dont waste your time.
Do a H/C/I with a forged bottom end. but make sure to replace the oil pan gasket while your down thereAweso....wait its just an oil leak lol. But i do have in mind a split port winstar sawp.
:facepalm::facepalm
Do a H/C/I with a forged bottom end. but make sure to replace the oil pan gasket while your down there![]()
Yeah i still need to clean it up a bit down there to better see where that leak is coming from. Hopefully its nothing major, but if it is, i could go with all the way up to replacing the piston rings.why rebuild a motor that just broke-in? if it aint broke dont fix it. remeber the mbabbit guy? 600K+ miles original eng. and internals. just clean the leaking area really good with a carb cleaner so there is absouletly no oil or dirt then scratch it a bit with sand paper and cover the whole area with permatex black. i have done this on timing cover leak and it has lasted 2 1/2 years now no leak. if its dont right it can work.
My shopping options are either ebay or a junkyard.i got a cam and push rods for $125. just gotta shop around![]()
That's what the shop manual says. It is necessary to support the engine fromTo my knowledge you have to drop the k member to get it out with the engine in the car.
