1 - 20 of 70 Posts
Its that time of year! Post any plans you have, or things you want to do to your stang this winter.
My plan is to build the motor
MMR1000 4.75L assembly (assembled/balanced at local machine shop)
HP s292 cams
Blow by Racing race ported heads (bought already)
Kooks Longtubes (bought already)
Kooks X pipe
Fuel system (cobra hat/GT pumps/FPDM/80lb injectors)
HPX slot style MAF
Send my V1 s trim in for the Si upgrade
IW 10% OD Harmonic balancer
Intake, not sure yet. Edlebrock or p51
Hoping to have it all togeather by april/may
Install my P1sc
K-member
Long tubes
LCA's
Abs delete
And someother odds and ends it should be fun.
Ill only have $3500 into the entire project when "done"
Well so far this "winter" ive installed gears, new cams and painted my fuel rails. And here is the list im working on now
Kb 2.2
8 rib pulley system upgrade
Gi joe gripper plate
Trunk mounted intercooler tank
Aeromotive gauge and boost gauge
Run 8an fuel line, new injectors, dual stryker 340s, dual fpdm, upgraded wiring
Cut my jlt intake to fit the kb
Paint timing cover
Egr delete
Install new lcas
Get car tuned!!
Hopefully I'll get most of this stuff done.
Absolutely getting done:
Install 31 spline axles, Cobra LSD, and 3.73's
Replace rear main
Replace seat covers(thanks Orange2v)
Paint my 02 side scoops and put them on
Install Mishimoto Radiator
Finish EGR delete
Possibly getting done:
Trade my deck lid out for one with no spoiler(already lined up with someone wanting to trade)
Replace quarters(depends on $$, already have the donor quarters)
Vortech kit or KB kit ( undecided)
Slammed
Tint
03-04 spoiler
03-04 side skirts
eBay cobra front bumper
That's the main stuff. I've got about 20-30 small things as well.
needs more boost
Install the v2-si
buy some longtubes and a prochamber to go with my lm1s...might sound bad? hope not lol
flsfcs
control arms
throw some cc plates on it and maybe new tires out back
The Mean Green
Im running out of parts to buy, dunno if Ill do much building this winter :(
Longtubes
HP292s
Nitrous
Clutch
Slicks and skinnies
teskid block
forged rotating assembly
ported/polished heads
upgraded oil pump/ windage tray
CMS stage 2 NA cams
full exhaust
24lb injectors - svt focus fuel pumps
HID's
tranny- getting rebuilt, and a shift kit
It'll be more of a spring build by the time I receive everything but ...
MMR 750SE 4.75L shortblock
On3 2nd gen FF turbo w/67mm cBB & billet wheel
UPR k frame w/CO's & CC plates
Full length SFC's & rear LCA's
340 pump w/BAP, 60# injectors, HPX slot MAF
Wideband A/F, boost/vac, oil pressure, fuel pressure gauges
Also swapping to a stock '96 cobra instrument cluster to carry white faced gauges thru-out.
Power will be limited to what I can get out of the single 340 and BAP. The price on this project has already gotten out of hand so a completely new fuel system with dual 340's are penciled in for next winter.
Besides all that I got to work in the price of a 6pt cage so I can get back on the track before the end of summer. :bash::baller:
i debating on selling her or keeping her :(
but if i do keep her, here's the list of parts:
hp292s
trick flows lash adjusters
4.10's
pan hard bar
steeda x2 ball joints
exedy mach 400 clutch
exedy flywheel
and all the misc **** that goes with that lol
Already done:
-fresh mach 1 lip
-mach 1 grille delete
-new lower shifter boot
Hopefully this weekend:
-Eibach PK springs, Koni Str.t struts and shocks, J&M street/race LCAs then off to get aligned
-have back glass and 2 rear side windows re-tinted
Late winter/early spring:
-new dyno tune and possibly more boost
-misc odds and ends
Stuff I hav bought and have yet to go on, will add to build lol..
Flsfc mm
Bbk strut tower brace
Tokico blues shocks&struts
Moog ball joints
Steeda bumpsteer
Canton coolant expansion tank
Canton power steering
Bullitt style auto pedals
Painted valve covers along with other painted stuff
99/01 cobra bumper along with fogs
Mm cc plates
And if all those things ever go on lol..my true build
Stall
Possibly cams
Probably should build my supercharger stronger I'm sure
Corbeau racing seats
Lots of stuff to do..
Putting this lift off hood on
swapping the old urp uppers for teamz uppers.
Get a new 75mm tb
upgrade my return fuel system from a dual pump to a triple.
putting a t56 in with a twin disk clutch
and get it tuned finally.
!FACEPLATED!
My normal, go thru the trans
I Need More Power!!!
Hopefully by Jan I will be in my new 2012 Super Bee, so the build consist of my new direction....
Get this 5.4 2V rebuilt
Pull 4.6
Find a 99-10 Cobra Bumper
DIY Rear Seat Delete
Battery Relocation
FLSFC
4.10's
Find the mysterious Rear end noise
Install new FR500's
UPR LCA's
Paint
1 - 20 of 70 Posts
