1 - 4 of 4 Posts
Is the game, Ross is the name.
For the last few days I have noticed that when I hit the brake pedal, it will go down a good amount with minimal braking power, then I let off and re apply and the pedal is much firmer and the car stops better.
IIRC, this means I need to like bleed the lines, correct?
Yep; make sure there's no air getting into the system. Bleed dem mo-fo's and check to see if the master cylinder is leaking and or check down at the calipers too.
1 - 4 of 4 Posts
