Status
Not open for further replies.
1 - 2 of 2 Posts
mm's nitrous mod
this is a sticky for power number's. the requirement for listing your power numbers is to pm me, futureMACH1racer, or lefty with your numbers, along with proof like a dyno graph or vid (vid must show numbers). if you would like to give you list of mods as well, add them in the pm and they will be listed as well.
blueone----------08 shelby gt---------617/575 PD blower
mm's nitrous mod
Discussion Starter · #2 ·
blueone:
: COMP CAMS VALVE SPRINGS BEEHIVE
: STAINLESS STEEL FERREA EXHAUST VALVES
: STAINLESS STEEL FERREA INTAKE VALVES (
: BULLITT RACING CUSTOM GROUND BLOWER CAMSHAFTS
: ARP 256-4202 2000 SERIES HEAD STUDS
FULL PORTWORK 3V HEADS
VALVE JOB, CUT SEATS FOR OVERSIZED VALVES
ABOVE IS ALL HEAD WORK AND HEAD PARTS
: STEEL COBRA 8 BOLT CRANK
: MANLEY H-BEAM W/ ARP 2000 BOLTS
: PISTONS CP/MOD MAX 14CC DISH
: FILE FIT MOLY RINGS
: FORD RACING OIL PUMP
: ARP MAIN STUDS
BORE AND TORQUE PLATE HONE
BALANCE ROTATING ASSEMBLY
Parts: MOROSO OIL PAN #20546
GT500 FUEL PUMP KIT
: FIDANZA ALUMINUM FLYWHEEL
: RAM 300/900 CLUTCH
: 60 LB INJECTORS
: KENNEBELL 8 RIB PULLEY SET UP
ARH 1 3/4" LT'S, HF CATTED X
1 - 2 of 2 Posts
Status
