Use motorcraft mercon atf correct? How much would it take to do a full flush?
Because its basically same thing.I also used tranny, fluid Flushing it is pretty self explanatory you want to add fluid to the Res and run it through the Rack and all the lines to flush it out at the lowest point so it can run through the entire system.And the fluid can get pretty nasty in there haven't this problem on my own vehicles but i have seen some nasty stuff out of other's.Just a ? why would you put automatic transmission fluid in a power steering resevoir?
Just regular power steering fluid. Not exactly sure on how to flush power steering fluid, im sure someone on here knows. I dont think the fluid gets to dirty in there.
Ford calls for ATF.^^ the actual power steering fluid is cheaper though. I would think that the viscositys are different between the two also. If it works it works.
