1 - 2 of 2 Posts
I have a 96 gt and the power steering goes in and out. Especially if the car sits for a couple of days it.seems like the steering is easy as pie and then slowly gets harder. If i drive it all the time it stays out. Can someone give me some pointers on what to check and do? Should i start with a new pump?
while running pull the res cap. check to see if the fluid is moving. if not then you need a pump. if its moving check you steering shaft. make sure all joints move free. if so move to the rack. make sure the rack moves freely.
1 - 2 of 2 Posts
