1 - 7 of 7 Posts
Where can i put an priming tool to pressurize the oiling system on an assembled 4.6L 2v? I almost have the motor together im just not sure where i can insert the tool. Any suggestions would be greatly appreciated.
a.k.a. Racecougar
I was told not to crank it without the fuel system because then the lash adjusters make contact un lubricated, could i put the priming system into the oil sending unit some how?
One would think Ford would know how to do this...
Pimp
Lol i used a bug pump spray bottle... Filled it with 5 quarts, pumped it filled it with the last quart pumped it up watched my gauge... pulled pump off oil feed and cranked up no issues.
a.k.a. Racecougar
While Ford's method does work to prime the system, it's intended to be quick/easy for their techs. Using an external source of pressurized oil to prime the system insures that everything receives pressurized oil without spinning the rotating assembly via the starter motor. It just takes a little more effort.
1 - 7 of 7 Posts
