problem with my diablo tuner.
well where to start.The problem is i just got some wheels and tires installed.Im trying to go in and change the rotation per mile.Ive done this more than once and know how to do it.I even did this bout 2 weeks ago.What hapeens is i go thru all the steps to change the parameter i want.Then i go to install tune and it says to turn the ignition on.I do and press continue.Then instead of going to the writing vehicle screen it say (did not see the ignition tun on) then it asks if i did and it has the continue icon.I press it and it says turn off then on.I do and it says could not install tune.I checked for codes and none.I switch it to moniter mode and it does that just fine.I can see everything running but the problem above happens again when i try to put in the tune again.
