1 - 14 of 14 Posts
My battery which I bought from autozone a year ago keeps dying. Basically my car is not driven, it's garaged, I disconnect both battery terminals. Give it several months and come back, connect the battery and it's dead. Enough to run radio but not enough to start. When I left it there it was charged good.
So the question, is it problem with battery or problem with me leaving it for 5 six months at a time?
I live in Florida, temps are 90s all year round.
It takes at least an hour or more of driving to charge the battery, and a battery constantly being charged wont die. if it never gets used the electrolytes will get like messed up and stuff. It kept a good full charge when you first got it? Or did you not really use it.
does it hold a charge for a week?
Yes. For a week no problem. For a month no problem too.
I didn't really use it, but it did keep a good charge. I can tell because I'd start it two months later and it will work.
I <3 Boost
its just cause its sittin so long with nothin goin on. before i moved to texas from washington my car would sit all winter and the battery would die if i didnt go out and let it run or drive it on those couple nice days.
Wow $45!!! At first I dismissed this option, thought it would cost too much. But $45 is affordable even in this economy. Question, I see a wall power plug, always thought battery tender is something you keep in the car. How is this thing used?
Another question. Is this a battery charger which checks battery status and charges it as necessary?
What's this Photoshop?
Use this just like a charger, but it is a slow low amp charge. It will go into float/maintenance when the battery is charged and if the battery goes back down to like 80% or so it'll kick back in. You don't have to unhook your battery. May come with ring terminals which installed will have a quick disconnect plug to connect and disconnect the tender, or just hook the clamps up real quick. We have a lot of these at work and are fixing to buy about 15 more to get rid of some older off brand. One battery made it 7 years I believe.
I didn't notice, but the other link said gel cell. Haven't tried any of those to know if they'll work on regular batteries, but here is the one for the normal style batteries.
7 years? wow im definitely lookin into one of these
Doc
You can pick up a battery tender for $20.00 at walmart.. probably less than that.
The day before you need the car just put the tender on a 2 amp/12 volt auto deep cycle over night.
We use tenders a lot with motorcycles.
And make sure the battery isn't on any type of cement when you store or charge it.
well, i looked up the service records and it was 8 years actually. Brand new in 95.
Battery Replaced - 5/1/2001
Battery Replaced - 11/4/2009
Pretty good for a vehicle driven roughly once every 3 months.
^+1, never place a battery on cement.
ooooohhh i thought you meant it sat with th etender for like 7 years without being started and still worked haha
1 - 14 of 14 Posts
