1 - 11 of 11 Posts
Just saw a procharger for sell on Craiglist. Its off a 95gt was wondering if I can install it in my 96 gt is it possible?
depending on whats included probably, you would need a modular based mounting bracket and intake pipe for sure
Rollin' 18/ pushin' 2
It would not be a direct fit but i am sure with some extra parts you could make it work.
I don't know. The best thing you could do is to call the manufacturer and ask them about the differences in the two kits. I am sure they could sell you the different parts you would need individually or tell you exactly what you would need so you could find them on your own.
NOVI SL Superchargers | Paxton Superchargers
Looks like the number is: 888-9-PAXTON
the 5.0 procharger is the wrong rotation for a 4.6 and will not be able to fit.
comp cams and a stall would really wake up your car.
Can I use a 90mm mass air meter/sensor and 24lb injectors. Would it b necessary? Or would it help a little?
you dont need a maf or injectors unless your maf is pegging or if the injectors are above 80% or so duty cycle. this typically doesnt happen til a little after 300 rwhp.
1 - 11 of 11 Posts
