What should I look at when inspecting a used P1SC? I know I should check for shaft play, is ANY amount normal, even small, whether it's when pushing/pulling or if moving it side-to-side? What else should I check for? The used kit I'm checking out tomorrow also includes 42# injectors, mounting accessories, tubing, and a Core 3 air-to-air intercooler. Anything I should look for on that? Thanks!
[EDIT]
From my understanding, in/out shaft play is BAD, just not sure how much, but I believe it shouldn't move at all. Side-to-side shaft play is fine as long as it's not a lot and the blades aren't scraping. Is this correct? Can somebody answer my other questions as well? Thanks!
[EDIT]
