1 - 12 of 12 Posts
i have been trying to search , a buddy of mine just picked up a procharged v8...
it appears to be the tuner kit with fmu or whatever....what's the base mail order procharger hp rating supposed to be?....anybody know?...
i can't seem to find anything....
it has green injectors and 2 55lph fp...and it is intercooled, but the pulley is alot bigger than mine, so i suspect it's a 6-8 psi pulley....
anybody know..??
since the kit comes with a 255lph pump and 42 pound injectors.. im 98% sure its 380-390 ish
i was thinking it was around 350 or so , being it has an fmu on the tb...the car was not dyno tuned, so i was thinking it was a safe mail order tune...does that make sense?..
yea im thinking more near 350.
US Air Force (retired)
The P-1SC with the standard 8 lb pulley will get around 350 rwhp through a manual transmission on a completely stock motor. 10 lb pulley get near 400 rwhp. The 42 lbs injectors and 255 lph fuel pump will support both pulleys.
seems like all the big brands for our cars at 8 psi usually make 350-380 depending on mods 10 psi usually nets around 400+ also depending on mods all those bolt ons come to life when you add a **** ton of air.
my procharger is running with 42lbs injectors. your probably looking at a 10psi... if you happen to be looking for one, mine is for sale actually! pm me... 10psi. less than a year old.
but procharger is definitely the way to go! the air to air performance is amazing...
Boost gets you laid
mine made 380.. it was around 10psi through stock cats on a conservative tune.. oh and with the big 3 core intercooler, that seemed to help a little. i'd say the tuner should put around 370-390 on a stock car
Discussion Starter · #12 ·
i guess you did'nt see my hp/torque on the left or the sc in my sig..:cool:
1 - 12 of 12 Posts
