1 - 15 of 15 Posts
Short throw
Right now i have smoked headlight covers from American Muscle and they look awesome but dont let hardly any light through making it very hard to see, even with the fog lights on and upgraded brighter bulbs. I was looking at the smoked projector bulbs on AM and they look like they would be way better lights except they dont look that "smoked". Some of the customer photos they looked like non smoked projectors. I also found the smoked OE style headlights and the appearance was way better cause they looked to be smoked darker. I guess my question is should I get the smoked projectors to give up the look but have better night time vision, or get the OE style with my brighter bulbs to keep the smoked look and still have good light getting through? If anyone has pictures of projector bulbs at night I would like to compare. And opinions are welcome! Thanks
It's a toss up MustangMan,
Personally, I really like the look of the OE smoked lenses, and brighter bulbs would help some. Although, if this car was my daily driver, I would definitely go with the projectors. IMO it's worth having the safety of solid lighting with a daily driver, since there will be times when you're stuck in storms or serve rain.
Just my opinion, good luck with your decision!
Shane
Short throw
yeah that's true saftey should come before style, I'm leaning towards the projectors, thanks for the input!
Sent from my VM670 using AutoGuide.Com Free App
I don't mean any disrespect to Am Muscle, but the Raxiom projectors are not HID projectors, they are halide projectors, and not very good at that. I suggest if you want real projectors, with HID lights that are as safe as the Lexus, or Ford OEM projectors, you do one of the following:
1. Buy morimoto projectors and pull apart your OEM or Raxion projectors, and retrofit the Moris in place of the Raxioms. This is relatively easy, and there are threads which show how this is done, using an oven and basic hand tools. You will need to pry the cover off of the headlight to retrofit the projectors. theretrofitsource.com has everything you need to do this yourself.
2. You can have a retrofitter do the replacement, and turn your OEM or Raxiom headlights into projectors. This will cost from $400 - $1000, depending on your wish list and amount of modifications you want to do. I recommend sickhids.com
This is a much cleaner option than sticking HIDs into the Raxioms, and will last for years to come. I have a 2011 V6 Mustang and I had my OEMs retrofitted by sickhids and they work great. No flicker, no humming, no problems when the weather gets wet.
eating 1 ricer at a time
Go on eBay and get the projector and 35w hid headlight kit it's 90$ for a smoked kit.
Sent from somewhere in the world other than home.
frankr,
This is true, they're not HID projectors. We don't suggest running HID's in factory and Raxiom housings in case they melt. However, I've seen plenty of our customers run low 35 watt HID's in both housings without any issues. This may be the route you want to take, we just don't suggest it from AM.
Let us know how you make out!
Shane
Short throw
Discussion Starter #10
frankr,
Shane
which HIDs are low 35watts? does that depend on whether they are like 6k or 8k HIDS? thanks
sent from THE FUTURE.
There's 35 watt and 55 watt HID's. I believe you can get any type lighting 5k, 6k, 8k, but the color/brightness isn't as intense with the 35watt, oppose to 55watt. I'm not positive if they go throughout all the ranges, but I have personally seen them in 5k, and 6k.
Hope this helps some, maybe someone can chime in that has more experience with HID's.
Shane
Short throw
Discussion Starter #12
Shane
that def helps thanks! and yes I hope someone chimes in too!
Buddy ordered smoked Projector lights from AM. Love the site dont get me wrong... they were ****.. adjustments broke.. with HIDs still couldnt see. Best way to get the Projector style is just like they said.. RETRO fit them. its worth the money honestly. I run HIDS in factory head lights all the time. never have an issue.. cheaper systems will melt a housing yes.. but if you buy a system that is made well you wont have any issues
"Junior, hold my hat!"
I just pulled my smoked lights off and replaced them with clear stockers I bought from AM! Couldn't see a damn thing with the smoked lenses at night and we don't have street lights in the town where I live. Smoked headlights look great but I needed better illumination so for $245 I went back to clear stockers.
1 - 15 of 15 Posts
