1 - 20 of 35 Posts
Ive always heard that you cant do underdrive pulley on these cars when you have added a sound system. ie sub and amp.. Is this tru? Thanks..
Alrite cool thanks guys.. What pulleys are u both using? Im looking into the steedas or bbk's..
It should be fine if the kit comes with an alt pulley.
Dude..that don't even make anysense.... If it comes with alt. Pulley hell be fine? Its the alt. Pulley that would possibly **** him... It comes with a bigger alt. Pulley meaning it won't be turning as fast meaning less charging...which could in turn possibly cause charging problems with a amp...in which case I'd put the stock smaller pulley back on...
!FACEPLATED!
My car had BBKs on it when I got it, but when I get around to it im going to get a set of steel Steedas. I dont like the aluminum ones
Yea thats what im gonna do leave the stock alternator pulley on..
I Poop Entirely Way Too Much
I had BBks and they were great. I removed them when I put the blower on though. Ill sell em if your interested pm me.
Penetration before detonation
I have the BBKs right now, and, other than the screeching ugly-ass noise when the A/C is on, they work great. I have a 350W amp and a Pioneer 12" and it works fine.
The noise would be caused by belt slip. That shouldnt be the pulley itself unless something were wrong with it.
My guy at LaMotta Performance said that because it's aluminum, the aluminum has worn off of the water pump pulley and embedded itself on the belt, causing the noise.
So, FYI, don't go aluminum.
Discussion Starter · #14 ·
Tanks for the offer man but it think im gonna go with the steel ones.. I might have a friend interested tho im not sure if he bought them yet but ill ask him and get back to you..
:2cents What you say? You don't want it? Anyways, personally, if you are only going to see around 5-8 hp gains from the kit in the first place, and you don't, or can't, use the Alt. pulley, that will probably put you down to around 2-5 hp gains. I just can't see the justification in spending that money on it then. I do have an idea though. Send me the money, and I will send you a cool sticker that you can feel about the same performance gain from. Sorry, having a bad week. On edge from this freaking custody battle that might cost me my deployment. It is a cool sticker though.;)
Discussion Starter · #16 ·
Lol well i hope everything works out for you with the custody stuff.. But ill pass on the sticker. But im at the point were the only other thing i cad do is pulleys then i have to move to cams heads stuff like that.. I can probably find the steedas for around $100 used like my friend did and he didnt use the alternator pulley and dynoed a 7rwhp gain i think it was.. Ill have to ask but im pretty positive thats what it was..
That doesn't make a lot of sense... If the aluminum is embedded on the back side i don't see it slipping...it slips at the crank pulley... I guess it could get embedded from the crank or alt. Pulley... Since its the grooved side... But I don't see the water pump slipping...especialy since its being turned so much slower...like..a lot slower...
!FACEPLATED!
The reason i want steedas right there... my belt is even silver from the pulleys
1 - 20 of 35 Posts
