1 - 6 of 6 Posts
Carving corners
So I will be dropping my transmission real soon and was wondering if anyone can give me any tips with solid motor mounts. I know with the stock mounts it has some play and allows the engine/transmission to sag towards the ass end which helps get to the top bolts, but mine being solid mounts will I run into any issues?
Mach1 FTW
when i yanked my motor before selling my car as a roller, if you have the motor mount bolts un-done and the trans crossmember completely removed, it will sag down quite a bit. atleast mine did.
Head Unicorn
Loosen the motor mount nuts on the K member side and it will rock far enough to give you room.
1 - 6 of 6 Posts
