1 - 5 of 5 Posts
Hey guys tried to search for the information but I could not find anything.
I picked up a complete cobra set up,fuel tank,hat,etc....
So my question is with the cobra set up and the ford gt pumps,what will the setup max out at??
With a boost a pump I think usually 750rwhp? I could be wrong. But youll also need a 2nd or modified FPDM.
I have 80lb injectors and I do not plan on running a boost a pump.
Dual fpdm's wire upgrade and a fuel line upgrade with rails should get you around 700 hp as long as your fuel pressure does not have to be over 65 psi. (20# of boost)
1 - 5 of 5 Posts
