96-98,01-04 gtIf your motor is stock they are press on. Just buy some new or used stock cam sprockets, and new cam bolts. For a 1996-96 or 2001-2004 gt.
is it possible to do cams without pullint the front timing cover?....i mean its not a big undertaking to get it off nor am i scared to do it by any means...just a simple question weather or not it is possible
How would removing the timing chain cover help with changing valve springs? Remove the lifters and rockers change the valve springs then the cams.yes it can be done,lot's of people have done it.anything over a stage 1 cam I would'nt Though. depending on cam size degreeing them would be prefered. and valve spring change's would be difficult if not impossible
