1 - 20 of 22 Posts
I have a jasper motor that was supposed to come with 280 hp....since then i added upper and lower intake upgrade, equal length shorty headers, x pipe, soon to get some heads. My question is what size fuel injectors u guys think i should get? Or when should you upgrade from the stock ones? Thanks.
i used typhoon...cheaper but soposedly similaar to edelbrok's.
i used typhoon...cheaper but soposedly similaar to edelbrok's. thanks for the responses guys
Discussion Starter · #12 ·
yea i just put a new fuel pump in...but it was a stock replacement. So i will have to get that 255..I got a tax return check coming so ill have to budget it out on everything i wanna get :) New hood coming in tommorow and a stage 3 clutch kit goin in tomorow so im pretty excited!
Discussion Starter · #13 ·
ill post pics once the hoods on, oh yea i got some headlights goin on too...gonna look bad ass! Thanks for the posts fellas.
wat headlights did you get
Discussion Starter · #15 ·
yeah that hood is pretty rare on foxes. IDK why, they look great on them. I guess because alot of people like the standard cowl hoods.
That number would be at 100% duty cycle.
yeah I would not run 19's with more than 275hp or so to be safe.. Some people will say otherwise but to be safe you dont want to lean out..
Also If you are gonna go to 24lb injectors I would put at least a 190lph fuel pump in the tank also.
Discussion Starter · #19 ·
will the car not run right with the 24's without the 190 fuel pump?
i didnt have a problem running the 24s with the stock pump i just thought i have the bigger injectors so i should get the pump to back it up so i ended up running the in tank 255
1 - 20 of 22 Posts
