I believe you need to get the V6 adapter kit, which is basically an H-pipe that you weld up after cutting the Y-pipe after the cats, then you can use the GT take-off cat-back. Now, If you get a custom exhaust set-up, you can use a "GT" after market mid-pipe and have it all welded up, but the stock isn't a direct fit.
