The lowest octane around here is 87, which is what i think most stock cars are recommended to use. 91 and up octane should really only be used if your car is tuned/high compression/heavily modded for it, it won't "hurt" to use it on a stock car but it also won't gain you anything using a higher octane, in the end it actually might sap a small amount of power from you.
