Call me captain insano, but I've never heard of having to bleed a cooling system. Since the system has an overflow, and is technically open to atmosphere, as the thermostat cycles open and closed, and the water pump circulates the coolant, any air bubbles will naturally work themselves out.
Is there something different once you bolt on an intercooler that I'm unaware of?
On standard style systems, like older cars, there is nothing to do other than what you said. Some modern systems require bleeding to remove all air pockets. This is usually systems where the radiator cap is lower than the higest point, or that have multiple complicated passages (like an LT1). These engines often have bleeder screws on the cooling system.
The system is not open to the atmosphere. The cap holds pressure, between 14-19 PSI usually, depending on the system. Coolant only goes into the overflow when the cap spring is pushed open to let coolant into the overflow tube. Our car does not have an overflow, it has a resevior and cap that is pressurized, rather than a cap on the radiator.
Usually, air bubbles CAN work themselves out on SIMPLE systems. But a lot of cars have areas that can trap air, like the header core, parts of the heads, steam pipes, etc. If air gets trapped, either it will cause a hot spot, or sometimes the thermostat won't open before the engine overheats.
A lot of modern systems also CANNOT be run to operating temp with the cap off. A lot of GMs are examples, as well as some Fords. This is because they run them so hot that without the pressure buildup from the cap, they would overheat. Pressure raises the boiling point of the water.
The term radiator bleeding is mis-used in the auto industry. Sort of dragged over from the old home sealed water heater days.
when they say bleed it, it's not bleeding at all. Your burping. The proper way to burp it is to run the car capless just like you mentioned for 15 minutes to operating temp, then turn on the heat on high for 5 minutes, cap still removed. This cycles the entire system including the heater core.
Shut down the car, put cap back on, wipe up any residual.
Erin, burbing and bleeding are two different procedures. What you said is burbing, but some engines have to be bled first. Let's use an LT1 as an example, it has two bleeder screws that need to be opened, then you fill the coolant and watch untill air stops comming out of them and solid coolant comes out (like brakes...), then close the bleeders and continue to "burb" it after that. Some cars won't even bleed without using a spill-free funnel to keep the coolant level real high.
But, I don't think our cars have any bleeders. never looked real close, I think it is a fairly simple system though.
What I meant was that eventually as the water pump cycles any remaining air bubbles would work their way out that way.... although what Erin said about leaving the cap off for a minute as you let the engine run... my bad. I just assumed that was common knowledge when topping off or refilling after a flush.
squeeze my hose
I guess I answered this above. One more thing though I dunno if I mentioned is that some cars it is VERY difficult to get the thermostat to open. I've had to raise the front end up like a wheelstanding competition to get some foreign cars to "burp" before.
OP: The vacume method uses a vacuum cooling system tool, I think they are called airvacs or something like that. It hooks to the radiator cap and pulls about 20 inches of vacuum on the system to "suck" air out. Then, you use that vacuum that is in the system to "suck" coolant in, filling any areas that would have air.
But, basically do what Erin said. Fill it up untill it stops bubbling and it's full. Start it and let it get hot with the heat on. Goose the throttle a couple times to create turbulence that helps dislodge trapped air. Then once the thermostat opens it will take more coolant. I then usually wait untill the fan comes on, then top it off, cap it, clean it and go for a drive. then top off as needed once you drive it.
