1 - 7 of 7 Posts
i got the radio part that is on top of the fender off the parts mustang and it looks like someone broke the antenna off inside the black piece on the fender how can i get it out so i can put my antenna in???
drill it out with bit smaller than what the antenna is
is there anyother way i dont have a drill (just started getting into mechanical stuff a few months ago :)
Rollin' 18/ pushin' 2
Delete it and install one of these instead:
HIDDEN ANTENNA
I put mine right behind the center of my back seat and filled the antenna hole on the fender. If you look at the pic in my sig you will see there is no antenna on my fender, it is a very clean look and I get great reception with that antenna in the link.
( Josh, you KNEW it was coming right?:p)
^ :blah
If he doesn't have a drill, I doubt he will have the material and tools to patch a hole in the fender. :p
No offense White :lol
Better than Drugs!
you finally get your car back White? Gotta see these pics man. Does the fender still have the piece that mounts to the fender and its broken off inside, like the screw part?
Better than Drugs!
you can always undo the piece mounted to tha fender, throw it away and go to the junkyard, pull off another one from some other fender. the smooth black cover pops off with a screw driver OR undo from below.
1 - 7 of 7 Posts
