1 - 5 of 5 Posts
Any know whete this wire is supposed to attach too? Its about three feet long. Is it abs? uploadfromtaptalk1354594437103.jpg
It is a 96 gt. Driversvside corner next to master cylinder.
Where does the other end lead? Looks like it passes thru the firewall? Is there a third wire? Unless its my monitor, i see a faint sliver of red and what appears to be two more wires. They are a bit fuzzy in the closeup. Does the ABS light go out? If it does the wires are for something else.
Do you have a light under your hood? It looks the same as the wiring I have unplugged due too having an aftermarket hood.
I do have an aftermarket hood. But it had the stock hood on the car when I bought it. But you may be correct. That could be why the wire is so long. I will chalk this one up to the hood light. My ABS light is on, and I thought it would be a great day if this wire was the attachment to the ABS wheel sensor, but it never works out this easy. Thanks for the help.
1 - 5 of 5 Posts
