just finished installing a raptor shift/launch light & thought I'd pass on how it went. first off their instruction's are non-existant as far as wiring hook up (not a big problem but why do they ask you what kinda car your putting it in if they're gonna send you generic directions?). they do have a mustang how-to no their web site but it's for a shift light only & your on your own to figure out the speed sensor wire (dark green with a white stripe by the way). install went easy enough (come's with 2 mounting clips & I used the instrament cluster bezel screw above the volt meter to mount the clip) & the programing instruction's were pretty clear. 2 big problems I found is the light isn't very bright compaired to other shift light's I've used & the launch feature isn't very smart as far as shutting off when the car starts moving. it does seem to work fine other than that & very east install (no tach interface box to buy). all in all I'd give it about a 5 out of 10
