1 - 10 of 10 Posts
The soul stealing Ginger
on a 2002 mustang v6 what is the component that houses the spyder gears called?
i got my traction lock in the mail a while back and my t-lock looks so much like the one sitting inside it already, why is that?
oh,i just saw somethign that was different, the one in my rear diff right now doesnt have that middle clip in between all the gears.
i dont think mine has that middle clip, what about this piece besides that middle one makes it different from the current one in there?
¡ʇsnq ɹo uʍop ǝpısdn
that clip is the "Clutch" for the rear end, ever heard of someone burning up there rear end? say a GT driver talkin bout that? what it means is he fried those clutches and they need to be replaced... suggested maintenance on them is 75k-100k
but those clutches is the difference between the T-lok and the open rear end
so if someone wanted a traction lock wouldnt they be able to buy a rebuild kit and just swap out gears and add the clip?
it will look like it
and actually no one has yet to say the correct name
what you have is called a differential case. stock is open diff, the new one you have is limited slip or a posi diff case
Discussion Starter #10
i knew what the one i got off order was, but now that you said open diff that rang a bell, thanx.
1 - 10 of 10 Posts
