1 - 12 of 12 Posts
im putting 4.10s and a t-lock wat else do i need as far as gaskets and stuff and what website can i get it all from
buy you t-lok from speedconcepts.net and the gears from americanmuscle.com Also get yourself the gear install kit from american muscle as well. Then you need friction modifier for the gear fluid. After you get everything put in.....drive the car easy for about 500 miles....change the gear fluid and put in synthetic.
MM's Resident Ricer
tlok
gears
master bearing kit
friction modifier
gear oil
MM's Resident Ricer
uhh probably a good bit, tell the dealership you got a ticket and you need to have your speedo readjusted they can do it, or most mechanic shops can do it or buy a tuner
MM's Resident Ricer
it will but a tuner is better
Ah good some else asking the same question. I was planning on getting everylthing in one shot from RPM Outlet here: Mustang 3.8L V6 Performance Parts FREE SHIPPING!
I was going to get motive gears & the FRPP t-lok.
They have gear oil and bearing kits there, too. Would this be alright?
1 - 12 of 12 Posts
