1 - 3 of 3 Posts
I have a 94 gt with a good rear end. And i have a 02 v6 that i want to put this into. Does anyone know what all needs to be done? I dont have the drive shaft for the gt Will bolts all line up and will drive shaft work from the v6?
The axle housing are likely different lengths. I know on the GTs the 99+ cars are about 1.5" longer than the 98 and earlier car housings. You should measure flange to flange to check.
Just an update. Everything lines up exactly and no issues with any of it. Driveshaft needs to be a bout 1/2” shorter but it easily slides into trans to take up that amount. The overall length is 1.5” shorter but no issues with stock tires. I Got bigger rims and tires that are 1” wider so that will take up the 1.5”loss from axles
1 - 3 of 3 Posts
