So I had my rear end rebuilt with FRPP 4.10 gears, new Trac lock, ext. Put an aluminum drive shaft in and there is a loud hum. Put the stocker back in and gone. Annoying.
Today cruising I notice the car shake at speeds above 55mph. Great. Now I never drive the car so this stuff I never notice until months later. All this rebuild and install stuff was done in October.
Google says frpp gears are motive made. Fantastic. I'm using royal purple 75w140 with a bottle of friction modifier. Some say red line is better.
I'm thinking of putting the aluminum back in and seeing what happens. If the shake is gone I know the reason is the drive shaft and then the humming is back.
Shop says aluminum drive shaft acts as a noise amplifier as its hollow so that's why I hear it.
Questions
Do I line up the dot on the tranny with the dot on the drive shaft then turn the wheels to line up that dot on the pinion? I have an aftermarket pinion on the rear since the stock leaked and the shop that did it made a tiny purple dot which I'm assuming is the dot I'm supposed to line up with.
This weekend I'm thinking of switching the ds and see what happens?
I know my tires are balanced and alignment is good. The shake is more of a mid car shake then steering shake.
Damned if I do. Damned if I don't. Ugh. Ideas?
Sent from my SM-G920T1 using Tapatalk
Questions
