I recently installed a set of 4.10 gears in my '02 GT conv. I can backup & turn in other direction ok, can drive at around town & turn left with out problems, but there is a gear grinding noise when I turn right.
I cleaned & inspected the plates in the pumpkin/ gears, etc... and thought everything was in good condition. Axles looked fine, I didn't see any abnormal wear on any part.
I will admit to not having had a backlash gauge, but put the pinion shim was re-installed when the new bearing was pressed on, etc...
Thanks,
Steve
Thanks,
Steve
