1 - 9 of 9 Posts
"out of order"
when i decel i hear a loud gringing noise, i searched and found out that it could be a pinion bearing gone bad?. be better to rebuild rearend or just replace pinion bearing??
"out of order"
i dont recall hitting anything but if reajusting the pinion angle or backlash would help any?
Open it up and assess the assembly for excess play. Have it jacked up and spin the driveshaft by Hans and listen to the bearings
Head Unicorn
Its possible, or if you hit something and the pinion angle got moved.
If any of you hit something hard enough to change the pinion angle you've just totaled your car. Sounds like a bearing a geat set issue, nothing to do with PA.
"out of order"
Discussion Starter #9
yea. that would suck. its been doing it for almost 7k miles now. and last time i changed diff fluid there were no metal specs in the fluid.. idk
1 - 9 of 9 Posts
