1 - 10 of 10 Posts
Another slow GT
Hey everyone, it's been awhile but it's good to be back. I'm assuming there was a garage update at some point during my absence because all of my garage info has disappeared and the format is new. Is there a way that this can still be accessed to be saved in a personal text file? I basically kept all of my modding progress in that space and it's a bit of a bummer that I can't seem to access it now. Any information will be appreciated.
Edit: The link to my old garage actually happens to be in my signature. Go ahead and give it a try. I get an invalid web address unfortunately.
Solution described below.
Another slow GT
Ok guys, found the solution. Go to my current garage link in a new tab(it has been updated): http://www.moddedmustangs.com/forums/vbgarage.php?do=view&id=55228
This is the updated, correct URL linking to everyone's garages. At the end of the URL, there is a user ID number which is linked to the account you are viewing. For example, mine was 55228.
Now, go to your old broken garage link. It also has a five digit number at the end of the string. Copy this number and substitute it for the number in the correct URL from my garage posted at the top of this post. Now, you should be able to view your old garage as it was. Copy the text and update it through the new garage channels.
Looks like the pathways were simply changed. Let me know if you have questions.
Thanks for pointing me in the right direction, Administrator.
Mod List:
Engine/Drivetrain
K&N Drop-in filter
C&L Intake Plenum w/ EGR Delete
SCT SF3 / X3 Handheld Tuner w/ 91 octane Bama custom tune
N2MB WOT Box
AEM 320lph Fuel Pump
UPR O/R X Pipe
Borla Stinger S-Type Catback
Steeda Tri-Ax short-throw shifter
T45 Source Billet 3-4 Shift Fork
Hanlon Motorsports carbon synchro blocker rings
Ford Racing 4.10 gears w/ Trac-lok carbon clutch discs
Suspension/Chassis
'03 Cobra Front Springs cut 1.5 coils w/o isolators
H&R SuperSport Rear Springs
Maximum Motorsports Bumpsteer Kit
Maximum Motorsports Caster/Camber Plates
Steeda X2 Balljoints
Prothane 4-1/4" Front Sway Bar Endlinks w/ Poly Bushings
Prothane Poly Front Sway Bar Bushings
Prothane Poly Steering Rack Bushings
Wheels/Tires
Front
18x9 Black 2010 GT500 Replica wheels
Nitto Motivo 245/40-18
H&R Trak+ Hubcentric Wheel spacers - 10mm
Rear
18x10 Black 2010 GT500 Replica wheels
Nitto Motivo 275/35-18
H&R Trak+ Hubcentric Wheel Spacers - 20mm
Appearance/Styling
Mach 1 Grille Delete
Mach 1 Chin Spoiler
OE Rear Spoiler moved back 2 in.
Third Brake Light Tint
6000k Kensun Bi-Xenon HID headlights
3000k DDM HID foglights
8 inch Shorty Antenna
OE CD Player removed and replaced with din pocket
Seat belt guides removed
VHT Tinted Rear Bumper sidemarkers
Chrome Bumper Letters
Soon to Come (Install)
'04 Mach 1 Rear Springs cut 1-2 coils w/o isolators
Front and rear spacers
Plans
Purchase Maximum Motorsports Full-Length Subframe Connectors
Purchase Koni STR.T Shocks/Struts
Purchase Lower Control Arms
Purchase Steeda Quick Release Quadrant/Firewall Adjuster
Purchase Jegs Clutch Pedal Height Adjuster
Purchase Trickflow 75 mm Throttle Body
Purchase/Build Custom aluminum intake w/ VMP Slot Style Maf + Tune
Tint Windows
Black Housing w/ clear reflector stock replacement headlights
Dreams
V1/2-Si trim (2.87 or 3.12 pulley: ~10-12 psi w/ intercooler, 3.33 or 3.6 pulley: ~8-10 psi w/o intercooler)
VMP Slot style maf
CX Racing Intercooler
Ford Racing 42 lb Injectors
50mm Tial Q BOV
PCV to Catch can
if you scroll all the way to the bottom of a page, you'll see a box. if you switch it to classic mode, it will restore the format of the forum to the better, i mean the old style. then under your avatar you'll see a link to your garage that will have all of your information
Hey guys,
Are the garages only giving you that error when you try to access it from someone's signature or were you finding this broken link in one of the navbars?
~Sheena
Another slow GT
It was simply an old link I was following. Before figuring this out, the nav bar would send me to an empty garage. I didn't discover any issues with site functions if that's what you're curious about.
US Air Force (retired)
I'm using classic. On the top bar under "User CP" the "Edit Garage" takes you to the old garage which people can see if they click on your name above your avatar and then click on "View Garage." If you create or edit your garage using the top bar "Garage" it creates a garage that people can see through the link below your avatar. They click on the link "Garage" and then on the car's name. The new garage lets you post more pictures.
1 - 10 of 10 Posts
