What is the easiest way to achieve a higher redline on a 01 GT? What kind of mods are cheapest to increase it?
+1:yescams/springs will allow you to get a little higher. Closer to the 7k line, but only like 500rpm above current limit. The real issue with your red line is the rods and pistons. They won't take the high RPM very well. So, if 500 rpm more isn't enough, it won't be as easy.
Y do you want to raise it anyway? You could deactivate the factory limit and throw a rod if your into that![]()
spinning a motor just for the sake of spinning isn't gonna help/make you faster. these cars stock stop making power around 5700/5800 (some even lower). you need plenty of seat time in your own car to figure out shift point's, there's no magic number, some cars like a higher rpm shift (5800 for example) some cars run a better number shifting lower. head to the track & start working it out, good luck.cause then you would have an extra 500rpm torun thru, causing you to shift later. Anyway, i had another question, where is the best RPM to shift at if you were racing?
cam example makes perfect sense but the o/p is trying to get extra rpm from a tb/ plenum, not gonna happen. as to the extra rpm so you don't have to shift, thats the clueless statement, ton's of people lower their shift point's & pick up et. very well proven point, just depends on the car/driver.You can make power higher than 6k with a new cam. The cam is what dictates your curve, along with your intake. But in general, if he gets a new cam, he can get 500rpm more out of the car. And anyone who says they don't want the extra RPM is clueless. Extra RPM is extra time you don't have to shift. True the car doesn't necessarily still make power past a certain point, but the Cam is what will decide that.
The best RPM to shift at is the point where you'll come into the next gear close to your peak torque RPM. You need to dyno your car to find where your peak hp and torque are, and you need to know the spacing between your gears, as the shift point may be different for each shift (i.e. 1->2, 2->3, 3->4, etc).cause then you would have an extra 500rpm torun thru, causing you to shift later. Anyway, i had another question, where is the best RPM to shift at if you were racing?
The heads play a HUGE part in that equation as well. Filter, intake tube, intake manifold, and heads all need to be able to flow more air. Adding extra force on the rods is not a good idea. If you have all of that, then go for it, if not, don't bother. Also if you plan on raising the limiter much, be ready to by some new rods and possible a new block and pistons if things go wrong.You can make power higher than 6k with a new cam. The cam is what dictates your curve, along with your intake. But in general, if he gets a new cam, he can get 500rpm more out of the car. And anyone who says they don't want the extra RPM is clueless. Extra RPM is extra time you don't have to shift. True the car doesn't necessarily still make power past a certain point, but the Cam is what will decide that.
Yeah I didn't want to complicate things to much, but this is the truth. Your whole engine is designed for a certain range. You can toy around within the limits, but you never really raise the limits untill you adjust Everything to match.The heads play a HUGE part in that equation as well. Filter, intake tube, intake manifold, and heads all need to be able to flow more air. Adding extra force on the rods is not a good idea. If you have all of that, then go for it, if not, don't bother. Also if you plan on raising the limiter much, be ready to by some new rods and possible a new block and pistons if things go wrong.
Road racing, not drag racingas to the extra rpm so you don't have to shift, thats the clueless statement
