1 - 20 of 22 Posts
Just a quick little question.
How do you remove your headlights? haha.
Told you, quick, haha.
Kidding, I have the general idea, I just dont want to mess something up, haha. Cant risk it.
MM's Resident Ricer
what year is your car?
MM's Resident Ricer
open hood
pull up two black pins behind headlights
pull out headlight
unplug
MM's Resident Ricer
nope
MM's Resident Ricer
yup no problem
So, I went out there, didnt see any pins. I saw what I thought was pins and pulled them out, but no luck with the head lights. Point me in the direction with a picture?
MM's Resident Ricer
man I dont have any but they are black two per side and sit on top of the light shaped like an upside down L with the tab you pull being on top of the light pull both straight up and then wiggle the light out
if you take pics of the top of the light i can show you
ok kool nm then
Discussion Starter · #12 ·
Alright, got the light out, now how to get the lens off.
Title says it all. Ive tried several things to get the lens off, but it wont budge.
MM's Resident Ricer
what the hell are you trying to do lol
and bake it in the oven for 10 mins on 450 degrees the pop the lens tabs off
do whatever your doing to it
pop the tabs back into place
put back in oven for 10 mins
apply even pressure to reseal it
MM's Resident Ricer
yeah I am its the only way to get the sealing glue soft enough to pull it apart, and use acetone to clean the lense it is all that will work
MM's Resident Ricer
its not hard just
preheat over to 450
place in headlight for 10 mins
use flathead screw driver to pry tabs off (be careful)
clean lenses well with acetone
clip tabs back in
place in over for 10 more mins
apply even pressure over lense to make sure seal is secure
pretty clean lights
if they are foged up from the outside doesnt that mean its permanent and time for new ones. cuz that how mine r and im lookn to get new ones off ebay
MM's Resident Ricer
no it is common with plastic headlihts the fogging and yellowing is a mold that grows you can clean it out
1 - 20 of 22 Posts
