1 - 14 of 14 Posts
what do you guys mean by this?
Quad shocks are like horizontal small shocks near the rear springs and shocks. from what I understand, they're supposed to help your launch, but are more beneficial when they're not there, and even more pointless when you have LCA's. So one of the basic fundamentals of weight loss is to ditch them
!FACEPLATED!
quad shocks arent there to help you launch, they are to prevent wheel hop from the crappy design of the stamped steel LCA's
don't you put in better control arms to stop wheel hop on launch? that's why I assumed they helped your launch
!FACEPLATED!
its not launching that the quads help with, they help with everything that LCA's take care off when you put an aftermarket set on.
so with a set of aftermarket LCA's i can ditch them? will getting rid of them make wheel hop worse?
Unless you run at the drag strip and trying to get your best short time (60'), I would keep them installed even going with aftermarket LCA's.
!FACEPLATED!
aftermarket control arms take away the problems from the stock control arms and quads are not longer needed. You can keep them if you want but they arent needed and probably wont even tell a difference
BYAHHHH!
these guys.
Discussion Starter #12
ah i see, hopefully i can pick up some LCA's this summer and ditch em!
Don't mean to be a dick here but f8l you said they don't help with launching and then you said it's not just launching that they help with... You confused me there for a second lol.
!FACEPLATED!
launching at the track they dont help with, but if you were to get on it at the street say at a stop light, then they help a little. When i here someone say launch, to me its leaving the line at high rpm's. in instances light that, quads do nothing
1 - 14 of 14 Posts
