1 - 16 of 16 Posts
i have a 95 gt with a 5.0 cobra motor if i remove the smog pump will it cause the idiot light to come on?
My 91 has had it's removed. No problems here.
Just pull it. Cap hose going into engine and then get a shorter belt. I don't know if it will throw any codes, but that's pretty much it.
yeh thats what i was planning on doing but do they make plates to block off the back of the heads also and if so were could i get these?
and thanks for the help.
What i did was take the plumbing that bolts to the back of the heads and cut it off and flipped them around and used gasket material so there would be no leaks worked great and its free if you already have the stuff
Discussion Starter · #12 ·
and any suggestion for tire size for 18s mine only has 17s now but im going to 18inch bullits and was wondering on what tire size to run to keep same ride height
1 - 16 of 16 Posts
