1 - 6 of 6 Posts
Good day to you all,
I have 2001 stage 2 Roush mustang convert with 168k miles. She still has the orginal Roush shocks and front struts. I believe it is time to change them out. Since Roush does not make them any more, what would you all recommendations for there replacements?
Thanks
What are you wanting? Are you looking to keep the OEM ride and height or are you wanting to tighten up the suspension?
Like to keep the same ride height as Roush set it up. Would not mind tightening up the suspension. So, yes to both questions.
I don't know the Roush suspension at all and the info on it is very limited. The biggest thing you want to keep in mind is spring rate, and then match a strut to to that. You'll get the best results that way. I tried to find the spring rate but was unable to anywhere, but I did find how much lower they are than stock and it looks like 1.5" in the front and .8" in the rear. A pretty average spring rate for street with that drop is between 350-450 lbs/in in the front and 150-250 lbs/in the rear which most any aftermarket strut will work fine with. I did also find that the struts we made by Bilstein but that is about it, and they could be custom valved.
With all that I can pretty safely say that Bilstein HD's would be a good match for what you are looking for. They will probably be a little stiffer than your current strut but will still ride very well. I have also heard Eibach Pro struts were pretty close to the OEM Roush feel, but that is just what I have read.
Bilstein:
https://www.maximummotorsports.com/Bilstein-HD-Dampers-C380.aspx
Eibach:
https://www.maximummotorsports.com/...ck-kit-1979-2004-Mustang-solid-axle-P809.aspx
I personally have the Bilstein HD's matched with some H&R Race springs with a 1.5" drop up front and a 1" drop in the rear, and the ride is fantastic. It's firm but forgivable and I don't have to dodge cracks, holes, or slight undulations in the road anymore, and it responds super well to hard cornering.
Thanks for the offer, I'll pass at this time.
---------- Post added at 08:16 AM ---------- Previous post was at 08:11 AM ----------
Bilstein:
Eibach:
Thanks for the helpful info. for the shocks. I believe you maybe right, about Bilstein making the shocks for Roush mustangs. You gave me a great place to start. Thanks
1 - 6 of 6 Posts
