1 - 11 of 11 Posts
I just canged my battery now my car revs up lights dim it does that only in the morning can't figure it out, already know about the idle the car needs to do after a battery change its been two Weeks already and nothing
Hardon Enthusiast
did you check your alternator when you changed your battery?
I took to AutoZone to c if that was the case main problem was the battery alternator wad good took it the dealer as well for maintence I told them about it that it revs whileI drive , will check the alternator butt if not that any other suggestions what could be the problem
FBGM
huh?
FBGM
Its just alittle difficult to read with no puncuation
Checked the alternator now its good found out I could clean the throttle sensor or msa to help but still cant pin point the problem
4 capital letters and 2 commas in your 3 posts makes it difficult to understand what your actually saying. Read your posts twice and still not sure what you are talking about. I'm not going to try and read them again because it's giving me a headache.
I don't think the battery would have anything to do with that unless it somehow spiked your PCM (doubt it). If you cleaned your throttle position sensor and the blades themselves, I don't have any idea. Sounds very odd though
Discussion Starter #10
I cleaned the throttle body and the maf sensor and.took care of the problem something so easy the dealer can find it with out research wtf lol
Lol yea that sounded about right. Touchy throttle bodies due to the drive-by-wire system. Most dealer mechanics aren't really expert troubleshooters so much as just techs for jobs where the issue is previously known
1 - 11 of 11 Posts
