1 - 8 of 8 Posts
17x9 up front and 17x10.5 in back,
WHat is the widest tire each can hold? I believe its 275 on 9s but i think that will rubb in the front?
US Air Force (retired)
I have 9x17 up front and 10.5x17 on the back. 275/40-17 tires do not rub on the front. If you are lowered then it might rub in really tight corners. I'm not lowered and have no problems.
Super Moderator
275 is as wide as you can go on a 9" rim but you will need spacers to keep the tire from rubbing, on the 10.5" rim the largest you can go is 315. I run this exact setup on my car others have put 335 on the 10.5 and it is not safe no matter what anyone says.
Super Moderator
315's will clear out back even dropped 2 inches.
1 - 8 of 8 Posts
