1 - 20 of 52 Posts
So I had an appointment today for 4 new tires. All is going good, but I get pulled into the shop to find out 2 of the rims are bent. Needless to say those rims are discontinued and i need 4 new rims... 5x114.3 18x8. That's what i need just need some opinions on what to get. Cheap but look sharp. I'm stuck with this size cause the tires are already on the bent rims, and can be swapped.
Junkyard was an option but 18x8 rims aren't common. 500 max, but i be pushing almost broke for 2 weeks.
1 Wheel Peel
500 can get you rims new if you don't get chrome
What is the tire width
1 Wheel Peel
What's the tire width though. If it's wide enough you can get 18x9 rims which are 130 a piece brand new
1 Wheel Peel
The 8 inch wide is the problem. I sent you a message by the waynabout some rims
1 - 20 of 52 Posts
