1 - 1 of 1 Posts
So after installing heads, cam and intake my stock lifter roller tips are not shiny anymore like they were with the stock cam. The rollers don"t necessarily look damaged just more of a dull looking surface. Is this a cause for concern ? Could it be from the higher valve spring pressure ? Obviously it is kind of hard to inspect the cam lobes unless I remove it and I would probably pull the motor back out to do that. So the lifter on the right is an old lifter and the one on the left is one of the original lifters that had been run with the new cam for a short period of time.
Thanks for any replies.
1 - 1 of 1 Posts
