1 - 8 of 8 Posts
I'm pretty sure it wont work but I was wanting to know if romeo heads will work on a windsor motor. im pretty sure they have different bolt patterns but just wanting to make sure. thanks
MM elder
Is there any advantage to one over the other?
no.
best to stick with whichever you have though, because aside from the valve covers being diffrent, the bolts into the head from the timing cover are diffrent also.
minor things, but it all adds up.
there are plenty of either head floating around, it's easy to find a match for your current heads.
Im running ported romeo heads on my windsor shortblock. valve covers need to match. Timing cover bolts going into the heads need to be the romeo bolt/size.
1 - 8 of 8 Posts
