rough idle
5612 Views 8 Replies 7 Participants Last post by  stang300a
well when i get to a stop i have a rough idle like if the car wants to turn off wanted to know if any one had the same problem and help me out thx
Jesse
1 - 9 of 9 Posts
vacume leak. i had the same deal happen to me. also clean the iac and run seafoam through it. but for sur tighten up all your bolts and connections on your cai.
vacuum leak is possible, could also be bad plugs.
that is also true maybe even wires. i also got new wires at the same time soo..... the wires could have also helped me.
does ur check engine come on?!?!?
I had an inscreidly rough idle and drive, mine was do to the ignition coil.
well there no code but i fix it i used some carburetor cleaner on the intake manifold throttle and clean it with a tooth brush it work well thx guys i was thinking on changing my sparks plugs witch brand do u recommend??? thx
Jesse
Jesse
motorcraft or autolite copper plugs
get some autolite coppers and some msd wires. i just changed mine a month ago and it idles and feels way better. oh yea and clean ur maf u will notice better idle too.
1 - 9 of 9 Posts
